ftp code deployment automation
David Valero
November 27, 2022
I have a bitbucket code repository and I manage it with the sourcetree tool. I want to "automate" all the steps (pull, tag, merge, push...) and the code deployments on a web and database server (it depends on the deployment that I have to do) In the case of the web it is via ftp to a specific route. Can you help me?
Aron Gombas _Midori_
There is a project called "ftp-deploy" for Bitbucket Cloud. It does exactly what the name suggests:
https://bitbucket.org/atlassian/ftp-deploy/src/master/
David Valero
November 28, 2022
help me , plaseee !!!
Igor Stoyanov
December 2, 2022
Hi @David Valero  . Check this example:
script:
  - pipe: atlassian/ftp-deploy:0.3.7
    variables:
      USER: my-ftp-user
      PASSWORD: $FTP_PASSWORD
      SERVER: 127.0.0.1
      REMOTE_PATH: /tmp/my-remote-directory
from ftp-deploy pipe mentioned above.
Although, check this guide with alternative tool usage.
Regards, Igor
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
