git pull fatal: Could not read from remote repository
Tyler Brandon June 10, 2015
Atlassian Stash v2.10.1
$ git pull
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
$ ssh -p 7999 git@<stash-server>
shell request failed on channel 0
So not an ssh/authentication issue.    Was working yesterday, not working this morning, working this afternoon, not working this evening.
What could it be?
Thanks.
Tyler Brandon June 11, 2015
Under load, Stash may be unable to handle all requests in an elegant way.
Thank you, Thiago and Balazs, for your help.
3IIE
April 22, 2020
here is how I got mine going.
https://stackoverflow.com/questions/13509293/git-fatal-could-not-read-from-remote-repository
Look for Tombarts answer.
In your .git/config add your username to the url and everything should work.
akzhol_b
April 8, 2019
Hello, I have same troubles.
I have two operation system Windows 10 and Virtual Mac OS in one machine. Everything was good,until one day i have meet trouble with push/pull my commits in virtual Mac OS. I can't push or pull from my repository only Mac OS.
I passed verification "iCloud Security" and after this happened.
What I've done:
1. I cleared ``known_hosts``
2. I Added new ssh-key in bitbucket.org
3. Tried to clone this repository on another folder.
Error message:
packet_write_wait: Connection to 18.205.93.0 port 22: Broken pipe
akzhol_b
April 8, 2019
Never mind, I migrated repository to gitlab.com.
Andrew Burton
September 25, 2018
If someone else wanders into this thread - I was accidentally sudoed into bash.  Apparently that's a no go on the push - see https://confluence.atlassian.com/bitbucket/troubleshoot-ssh-issues-271943403.html
Logged off the sudo and was able to push again.
Muhammad Ibrahim
August 9, 2018 edited
You have to make sure that your repository name is the same as the one in your url link
e.g  git remote add origin git@bitbucket.org:username/your-repository-name.git
Then you push.
Jari_Fredriksson
October 9, 2017
I have this same error per now. It worked earlier but not now.
I can clone using https, but not ssh. The error shown is the same as presented in this question...
In bitbucket.log there is this:
2017-10-09 18:12:52,988 INFO  [ssh-scm-request-handler] jenkins @XQ6B4Fx1092x38x0 1p1nx9x 127.0.0.1 SSH - git-upload-pack '/lif/com.liferay.portal.plugins.sdk-7.0.git' c.a.b.i.ssh.server.SshCommandAdapter git was successfully authenticated via public key, but is no longer active in the underlyinguser directory. The request has been blocked
I'm pretty sure the OP would have had something similar in Stash back then...
Balázs Szakmáry
June 10, 2015
Since you say "Was working yesterday, not working this morning, working this afternoon, not working this evening", I doubt that Thiago is right about your user rights. (He might be right, but then somebody took your rights away to the repo, gave them back and took them away again.)
Try these:
  • If you can browse the contents of the repo on the Stash web interface, you can connect to Stash and do have at least read rights, so the issue is probably with the SSH connection.
  • If the above works, check that your SSH public key is correct in your profile (http://<stash server>/plugins/servlet/ssh/account/keys) and that your SSH agent is running on your machine and has your key loaded.
  • If all of these are OK, you might have a firewall on your computer or somewhere else blocking the connection to Stash.
Confirmed, I can browse the contents of the repo on the Stash web interface. The "shell request failed on channel 0" proves there is nothing wrong with the network (server accessibility) or the ssh authentication. We are exploring a possible loading issue (tens-of-thousands of accesses, yesterday, from a CI server).
ThiagoBomfim
June 10, 2015
Hi Tyler,
It seems that you have a SSH key uploaded but no read access to the repository in Stash as per the error below:
$ git pull
To solve that, please talk to your Stash admin so you can be assigned the right permissions.
The error below is expected because it should not be possible to get a remote shell via Stash (we use http://mina.apache.org/sshd-project/index.html for our SSH server):
$ ssh -p 7999 git@&lt;stash-server&gt;
Please refer to https://jira.atlassian.com/browse/STASH-3372
Best,
Thiago
The admin has not being revoking, then reissuing the access permissions. Thanks.
ThiagoBomfim
June 11, 2015
Hi Tyler. I am glad that this answer has helped you and you found the culprit ;)
Like • elquna likes this
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
