I am on Windows 7 Ultimate 64 bit, running Subversion 1.7.6 with Git version 1.8.0.mysysgit.0
I have Git running from a Bash window, not from a Windows command window
I am following the instructions to migrate my OnDemand Subversion repository to BitBucket - http://go-dvcs.atlassian.com/display/aod/Migrating+from+Subversion+to+Git+on+Bitbucket
Everything seemed to go well on the first section labled "Prepare." When I went to the "initial clone" page (http://go-dvcs.atlassian.com/display/aod/initial+clone) I ran into a few issues immediately with the git svn clone section. First of all I was getting an error that said "Expected FS format '2'; found format'4'. I found help for that which recommeded that I add the --pre-1.5-compatible flag to the svnadmin create command from the previous page. So, I remade my local SVN repository with the flag and the error went away.
I tried the command again, as follows:
$ git svn clone --trunk=/trunk --branches=/branches --tags=/tags --authors-file =authors.txt file:////c/Temp/SVNMigration/TempProjects/TEST test.git
This returns the error:
svn-remote.svn: remote ref '/Program Files (x86)/Git/trunk:refs/remotes/trunk' must start with 'refs/'
I looked at the remote section in the git config file in my newly created test.git repository, and found the following:
[svn-remote "svn"] url = file:///c/Temp/SVNMigration/TempProjects fetch = TEST/C:/Program Files (x86)/Git/trunk:refs/remotes/trunk
Since this file was created by the process, how could it be the problem? How do I fix this?
Scott
If someone happens to be in the same sittuation (if you search for "git config fetch = C:/Program Files (x86) remote ref" this page is the first result) I resolved this problem changing the clone command from:
$ git svn clone --authors-file=authors.txt --trunk=/trunk --branches=/branches --tags=/tags/Release http://internal.website.local/svn/project git-project
to this:
$ git svn clone --authors-file=authors.txt --trunk=trunk --branches=branches --tags=tags/Release http://internal.website.local/svn/project git-project
Note the removed leading slash "/" from the trunk, branches and tags parameters.
As I said, I recived this error in Windows. Switching to Ubuntu fixed the problem, although, according to the directions, Windows should have worked.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
