git-svn problem with svn-migration-scripts.jar
John Y July 25, 2018
I have been google like crazy for the following error on Sierra for the last couple days with no luck. Any pointer will be much appreciated!
svn-migration-scripts: using version 0.1.56bbc7f
Git: using version 2.18.0
Subversion: using version 1.9.7
Can't locate SVN/Core.pm in @INC (you may need to install the SVN::Core module) (@INC contains: /usr/local/git/share/perl5 /Library/Perl/5.18/darwin-thread-multi-2level /Library/Perl/5.18 /Network/Library/Perl/5.18/darwin-thread-multi-2level /Network/Library/Perl/5.18 /Library/Perl/Updates/5.18.2 /System/Library/Perl/5.18/darwin-thread-multi-2level /System/Library/Perl/5.18 /System/Library/Perl/Extras/5.18/darwin-thread-multi-2level /System/Library/Perl/Extras/5.18 .) at /usr/local/git/share/perl5/Git/SVN/Utils.pm line 6.
BEGIN failed--compilation aborted at /usr/local/git/share/perl5/Git/SVN/Utils.pm line 6.
Compilation failed in require at /usr/local/git/share/perl5/Git/SVN.pm line 25.
BEGIN failed--compilation aborted at /usr/local/git/share/perl5/Git/SVN.pm line 32.
Compilation failed in require at /usr/local/git/libexec/git-core/git-svn line 22.
BEGIN failed--compilation aborted at /usr/local/git/libexec/git-core/git-svn line 22.
git-svn: ERROR: Unable to determine version.
John Y November 1, 2018 edited
Problem resolved. Instead of doing installing perl (cpan SVN::Core)
I made use of brew to install both git and svn on and was able to finish the prepare step
$ java -jar ~/svn-migration-scripts.jar verify
Git: using version 2.19.1
Subversion: using version 1.10.2
git-svn: using version 2.19.1
Ana Retamal
July 26, 2018
Hi John, can you give us some more information to help us troubleshoot this issue?
  1. Are you using Bitbucket Server or Cloud?
  2. What operation are you performing when you receive this error?
  3. Is it consistent across different computers/networks?
Best regards,
Ana
John Y August 10, 2018 edited
Ana, I was preparing my local Mac Sierra for the migration by following step written down here https://www.atlassian.com/git/tutorials/migrating-prepare
The specific command steps was executing from terminal was:
Any help will be appreciated!
