We have Bitbucket self-hosted internally. There is no pipelines icon in my interface, and even if there were, we don't use containers.
I looked at the Bitbucket hooks documentation and it looks like you have to write an entire plugin, and the documentation is not stellar there.
Is there a simple way to trigger a shell script post-merge in Bitbucket? I am not finding it.
Thanks.
Hi, yes. There is a solution to your problem.
Disclaimer: I'm a maintainer of this product. If you have any questions, you can drop me a line and I'll guide you: we@reconquest.io
Thanks for your reply.
Effectively, what you are saying is, there is no way to do this short of using a plugin?
