how to use scp deploy in bitbucket pipeline
nexus_hardik June 17, 2019 edited
Hello Guys
I need to real time example how i can use  scp deploy step by step from beginning
my bitbucket pipeline code as below
- pipe: atlassian/scp-deploy:0.3.3
variables:
USER: $USER
SERVER: $SERVER
REMOTE_PATH: '/var/www/html/demo1'
LOCAL_PATH: $BITBUCKET_CLONE_DIR
EXTRA_ARGS: '-p 22622'
SSH_KEY: $MYKEY
Above code working perfect fine now but have once issue like below
 deployment success then there is one folder create name like build on remote path then it will clone particular repo in build folder.
how to resolved this.
mwatson
June 18, 2019
nexus_hardik June 19, 2019
Hello Matthew Watson
Yes have same problem and it is resolved now.
Thank you.
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
