http://localhost:7990/setup does not open
Ram_Kuchakulla April 24, 2014
Hi, i am unable to open the setup wizard as ths page http://localhost:7990/setupdoes not open
Nic Brough -Adaptavist-
April 25, 2014
You need to read the log files to find out why the application is not starting correctly.
Ram_Kuchakulla April 27, 2014
Hi Nic,
i didnt have the GIT installed and it also mentions need to stash.git.notfound[Stash, 1.7.6, 1.8.4.3]. The latest version i find is git 1.9.2. Will it work if i download this version or do i need an older version mentioned?
April 27, 2014
You should use the latest versions of git, and check your log file for more errors.
Ram_Kuchakulla May 5, 2014
Thanks it worked.
Naveen Babu January 24, 2019
git push -u origin master
fatal: NullReferenceException encountered.
Object reference not set to an instance of an object.
fatal: Authentication failed for 'http://localhost:7990/scm/test/test.git/'
January 24, 2019
I'm afraid a snippet of error message, without any context, on a 5 year old question that does not seem to be related, is not a lot of use to anyone.
Please could you ask a new question, including the context and tell us why you think it should work (as all we can tell from the error is that you've not got the right user/password)
Naveen Babu March 19, 2019
how to resolve please give a suggestion
March 19, 2019
We can't - you have not given us any useful information beyond an error that you simply have the wrong username and password for the git server.
Hi, i didnt have the GIT installed and it also mentions need to stash.git.notfound[Stash, 1.7.6, 1.8.4.3]. The latest version i find is git 1.9.2. Will it work if i download this version or do i need an older version mentioned?
CelsoA
April 25, 2014
Hi Ram,
Could you please try opening ip:7990 to check if the setup is correct displayed?
Also, are you using Windows or Linux?
We have installation guides for both systems:
https://confluence.atlassian.com/display/STASH/Installing+Stash+on+Windows
https://confluence.atlassian.com/display/STASH/Running+Stash+as+a+Windows+service
https://confluence.atlassian.com/display/STASH/Installing+Stash+on+Linux+and+Mac
Please check them and let me know how it goes.
Celso Yoshioka
Hi Celso,
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
