#We want following to check also
Jira must not be a story or epic.
Jira must be in-process status.
#!/usr/bin/python
- JIRA commit acceptance python client for SVN
- Author: istvan.vamosi@midori.hu
- $Id: jira-client.py 10144 2007-09-12 10:13:37Z ferenc.kiss $
import os
import sys
import urlparse
import xmlrpclib
- configure JIRA access
- ("projectKey" can contain multiple comma-separated JIRA project keys like "projectKey = 'TST,ARP'".
- If you specify multiple keys, the commit will be accepted if at least one project listed accepts it.
- Or you can specify "projectKey = '*'" to force using the global commit acceptance settings if you don't
- want to specify any exact project key.)
jiraBaseURL = 'https://jira.crossview.com'
jiraLogin = 'SN'
jiraPassword = 'TESTABC'
projectKey = 'ABC'
- configure svnlook path
svnlookPath = '/usr/local/bin/svnlook'
#svnlookPath = 'C:\\Progra~1\\svn-win32-1.4.0\\bin
svnlook.exe'
- get committer
try:
f = os.popen(svnlookPath + ' author ' + sys.argv[1] + ' --transaction ' + sys.argv[2])
committer = f.read()
if f.close():
raise 1
committer = committer.rstrip("\n\r")
except:
print >> sys.stderr, 'Unable to get committer with svnlook.'
sys.exit(1)
- get commit message
try:
f = os.popen(svnlookPath + ' log ' + sys.argv[1] + ' --transaction ' + sys.argv[2])
commitMessage = f.read()
if f.close():
raise 1
commitMessage = commitMessage.rstrip('\n\r')
except:
print >> sys.stderr, 'Unable to get commit message with svnlook.'
sys.exit(1)
- print arguments
print >> sys.stderr, 'Committer: ' + committer
print >> sys.stderr, 'Commit message: "' + commitMessage + '"'
- invoke JIRA web service
try:
s = xmlrpclib.ServerProxy(urlparse.urljoin(jiraBaseURL, '/rpc/xmlrpc'))
acceptance, comment = s.commitacc.acceptCommit(jiraLogin, jiraPassword, committer, projectKey, commitMessage).split('|');
except:
acceptance, comment = ['false', 'Unable to connect to the JIRA server at "' + jiraBaseURL + '".']
if acceptance == 'true':
print >> sys.stderr, 'Commit accepted.'
sys.exit(0)
else:
print >> sys.stderr, 'Commit rejected: ' + comment
sys.exit(1)
