pipeline doesnt recognize origin/master
Evan Wu
December 24, 2018 edited
I'm running pipeline on a angular workspace project power by nrwl.
and I have a npm script that reference the branch (`origin/master`)
node --max_old_space_size=8192 ./node_modules/.bin/nx affected:lint --parallel --maxParallel 8 --base=origin/master --head=1ffcde318bba511382be7bd44cfdccb186e063a1
 (Note the --base option)
this will work when the pipeline is running on master branch but I kept getting
fatal: Not a valid object name origin/master
when running pipeline on other branch.
I thought it's because master is not fetched, so I add
git fetch origin master
before I run the other command, and from the log I can tell that master is being fetched but I still get the error.
Does anyone know how to resolve this?
5 votes
Steven Vaccarella
January 13, 2019
Hi Evan,
I suspect your "git fetch" command is not working as expected because Pipelines doesn't do a full clone and this results in a git configuration that won't automatically create remote tracking branches for other branches (besides the one being built). To fetch a different branch, try something like this:
git fetch origin master:refs/remotes/origin/master
This should create the remote tracking branch "origin/master" regardless of the current configuration.
dan.foley
January 19, 2021
Same, using nx and encountering the same issue.  This solved the problem.
Like • Garrett Hughes likes this
Garrett Hughes
November 28, 2023 edited
deleted
