As the title said, the pipeline can only display the result of testing, but not stack trace of the error. The testing XML output file is generated automatically by gradle and it includes stack trace.
I'm wondering how should I make it show all information.
Hi Jie,
We recently fixed a bug that caused Gradle test logs to not render properly in the UI. Can you please check whether you are still experiencing this problem? If you are, please raise a support ticket so that we can look at your repository in more detail.
Aneita
