×I am currently using Bitbucket v8.9.9 and installed the plugin for sonar for bitbucket. I also installed sonarqube version 9.9.3 community edition. The issue i am facing is whenever I raise a pull request to merge a feature branch with main branch i get below error:
"No Sonar data found for project "ABC_project". Please wait for the build to be finished or check your build configuration and reload this page afterward".
For every PR i am getting the same error.
Can anyone please suggest on this.
Hi
The error message suggests that no analysis of the pull request exists in the SonarQube project. You can check your configuration by following our troubleshooting guide.
Feel free to create a support ticket if you cannot get it to work.
Christian - Mibex Software
