"Write access is required for uploading LFS objects" when pushing to repo
FreakingPingo September 22, 2017 edited
An error have begun popping on different machines in our office and we are not exactly sure what is causing it. We haven't done any modifications or changes to our setup that would cause such an error. It is only a handful of our git users that are experiencing this.
We figured out we could resolve the issue by switching from HTTPS to SSH, but we would much prefer to stay using HTTPS.
Here is a trace output of the error.
$ GIT_TRACE=1 git push
12:26:00.778498 git.c:328 trace: built-in: git 'push'
12:26:00.780504 run-command.c:626 trace: run_command: 'remote-https' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
12:26:00.801539 git.c:560 trace: exec: 'git-remote-https' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
12:26:00.802040 run-command.c:626 trace: run_command: 'git-remote-https' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
12:26:01.783649 run-command.c:626 trace: run_command: 'git credential-manager get'
12:26:01.844961 git.c:560 trace: exec: 'git-credential-manager' 'get'
12:26:01.845463 run-command.c:626 trace: run_command: 'git-credential-manager' 'get'
12:26:04.002673 run-command.c:626 trace: run_command: 'git credential-manager store'
12:26:04.062128 git.c:560 trace: exec: 'git-credential-manager' ‘store'
12:26:04.062631 run-command.c:626 trace: run_command: 'git-credential-manager' 'store'
12:26:04.346886 run-command.c:626 trace: run_command: '.git/hooks/pre-push' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
12:26:04.410756 git.c:560 trace: exec: 'git-lfs' 'pre-push' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
12:26:04.411257 run-command.c:626       trace: run_command: 'git-lfs' 'pre-push' 'origin' 'https://USER@bitbucket.org/COMPANY/REPO.git'
trace git-lfs: run_command: 'git' config -l
trace git-lfs: run_command: 'git' version
trace git-lfs: tq: running as batched queue, batch size of 100
trace git-lfs: pre-push: refs/heads/master 0b4dbace014695ef730e38a118192d6e128dfdf5 refs/heads/master 8c98bf5fd8e7548866421810e7b0f00edcaf3924
trace git-lfs: run_command: git rev-list --objects 0b4dbace014695ef730e38a118192d6e128dfdf5 --not --remotes=origin --
trace git-lfs: run_command: git cat-file --batch-check
trace git-lfs: tq: sending batch of size 1
trace git-lfs: api: batch 1 files
trace git-lfs: creds: git credential fill ("https", "bitbucket.org", "COMPANY/REPO.git")
trace git-lfs: Filled credentials for https://USER@bitbucket.org/COMPANY/REPO.git
trace git-lfs: Error reading cert file "/ssl/certs/ca-bundle.crt": open /ssl/certs/ca-bundle.crt: The system cannot find the path specified.
trace git-lfs: HTTP: POST https://USER@bitbucket.org/COMPANY/REPO.git/info/lfs/objects/batch
trace git-lfs: HTTP: 403
trace git-lfs: HTTP: {"message": "Write access is required for uploading LFS objects"}
trace git-lfs: api error: Write access is required for uploading LFS objects
Git LFS: (0 of 1 files) 0 B / 131.03 KB
batch response: Write access is required for uploading LFS objects
error: failed to push some refs to 'https://USER@bitbucket.org/COMPANY/REPO.git'
I believe I found a solution to the problem. I forgot to mention that we were using Sourcetree. In the above mention log the following error was produced:
It appears that there are some issues reading the certificate to establish a SSL connection.
I figured out that you could reset / re-add the certificate by clearing your current credentials and re-enter them. Because we were using Sourcetree we removed all credentials for the user in Sourcetree and got the user to log in again. After doing so, we could once again push to out LFS server.
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
