"docker: command not found" error when running code-deploy pipe
Julien Richard-Foy
March 27, 2019
I’ve copied the `script` entry given in the documentation of the atlassian/aws-code-deploy pipe and adapted to my needs:
pipelines:
branches:
master:
- step:
image: node:10
script:
- step:
script:
- pipe: atlassian/aws-code-deploy:0.2.1
variables:
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
AWS_DEFAULT_REGION: 'us-east-2'
APPLICATION_NAME: $APPLICATION_NAME
COMMAND: 'upload'
ZIP_FILE: $ZIP_FILE
S3_BUCKET: $S3_BUCKET
When the pipeline is run, I get the following error:
 docker container run \
--volume=/opt/atlassian/pipelines/agent/build:/opt/atlassian/pipelines/agent/build \
--volume=/opt/atlassian/pipelines/agent/ssh:/opt/atlassian/pipelines/agent/ssh:ro \
bash: docker: command not found
My pipeline is using the default Docker image.
4 votes
Julien Richard-Foy
March 27, 2019
I was able to fix the problem by adding the `docker` service to my step:
 - step:
services:
- docker
script:
variables:
Radu Cristescu April 11, 2025 edited
For me, this was caused by BCLOUD-22851. I have self-hosted runners where this error happens once in a blue moon.
I have a cron job on the lookout for this bug. For each runner, it looks for the `docker` directory. If it finds it, it stops the runner, removes the directory, and starts the runner again.
Unfortunately, a pipeline has to trigger the problem before the workaround kicks in, so the pipeline that triggers it will fail. But because the workaround kicks in automatically via cron, rerunning the pipeline will be fine.
helgispbru
December 21, 2020
I have the same issue and this solutions doesn't help me.
Dipesh Rane March 1, 2021
pipelines:
branches:
master:
- step:
image: node:10
script:
- step:
services:
- docker
script:
variables:
COMMAND: 'upload'
ZIP_FILE: $ZIP_FILE
add docker as services it will fix the issue
Like Cuneyt Gurses likes this
Peter
May 31, 2021
You must have a reserved Variable called PATH, in your enviroment.
Xinyi Xu
May 22, 2020
Hey, accepted answer doesn't work for me. I was able to make it run adding optioins:docker: true to the end. See below
pipelines:
branches:
master:
- step:
image: node:10
script:
- step:
script:
variables:
COMMAND: 'upload'
ZIP_FILE: $ZIP_FILE
options:
docker: true
Samuell
March 27, 2019
I had same issue i just reruned pipelines again and it works.
