×I'm looking to make code reviews a required step to accept code into our code base. Been playing with Stash & Crucible to see how they could be setup to help me accomplish this, but am struggling to find a good answer.
To start with, I think the basic features I'm looking for (with the https://www.atlassian.com/git/workflows#!workflow-feature-branch in mind) are:
Stash, via the "pull request" system seems to cover only #2 (and #5?), but not the rest, although it's pretty close on #1 as it has ACLs for branches, but not based on pull request status.
Crucible, surprisingly seems to fall short on all fronts. (uh?!) What am I missing here?
Curious about whether I'm looking at this the wrong way, or whether there are plugins/hooks that'd do the job here.
Hi Chris,
How did you go?
1. This isn't currently possible without writing your own plugin. You might be interested in the following:
https://jira.atlassian.com/browse/STASH-2910
2. Yep.
3. Again you could do this with a plugin. There are quite a few open feature requests around reviewers, but nothing that matches that exact requirement. You might want to do a quick Google if you're interested. See below also.
4. People with write access should be able to approve without being a reviewer. Is that what you had in mind?
5. Again, people with access should be able to add themselves or others to a pull request.
In general we're planning on enhancing the whole pull request experience in feature releases. I can't be more specific around dates or exact features, but we'll certainly be keeping 1 and 3 in mind.
Charles
