xsrf check failed creating project bitbucket server using python request
Jeremie Labbe
November 2, 2016
Hi Team,
I'm trying to create a project using a python script and the requests library.
When doing get requests, I have no problem, but when doing post requests, I encounter a "xsrf check failed"
Here's the snippet:
payload = {"key":"EQSS_TST", "name":"qtm_test"}
r = requests.post('http://server.co.uk:7990/rest/api/1.0/projects', params=payload, auth=(user,password))
The error message is "XSRF check failed"
Thanks for you help!
Jeremie
3 votes
Ulrich Kuhnhardt _IzymesDev_
November 2, 2016
The POST request header must contain Content-type = application/json
Stan Ry
November 11, 2019 edited
I've had a similar issue with posting comments through response.post(), and it solved with adding the following lines to the header:
 'x-atlassian-token': 'no-check',
'x-requested-with': 'XMLHttpRequest',
 So the session object looks as follows:
s = requests.Session()
s.auth = auth
s.verify = False
s.headers = {
'origin': 'https://myserver.example.net',
'pragma': 'no-cache',
'user-agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.186 YaBrowser/18.3.1.1220 Yowser/2.5 Safari/537.36',
'content-type': 'application/x-www-form-urlencoded; charset=UTF-8',
'referer': 'https://myserver.example.net/instance_name/pages/viewpage.action?pageId=123456789',
and response object looks as:
r = s.post(
'{}'.format(WEB),
params = params,
data = data,
print(r.text)
where
WEB = 'https://server.example.net/instance_name/pages/viewpage.action?pageId=123456789'
params = {'actions':'true'}
data = {
'html': '<p>Test</p>',
'watch': 'false',
'uuid': '54b022eb-e098-a3ad-5f8d-fd68619681fb'
Jeremie Labbe
November 3, 2016
I'm not planning on adding an avatar to the project so I shouldn't need to define the content-type.
The example prototype on the documentation says:
    "key": "PRJ",
    "name": "My Cool Project",
    "description": "The description for my cool project.",
    "avatar": "data:image/png;base64,<base64-encoded-image-data>"
Has anybody ever created a project using the "requests" python library?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
