“No matter what people tell you, words and ideas can change the world.”
—Robin Williams
Atlassian believes all teams have potential to do amazing things. The Atlassian Community is a team where we can go to find inspiration, answers, and support. One important part of this community is accepting a solution.
When you start a new question in the Atlassian Community, you have the ability to accept any of the replies as the solution to your question. If more than one answer was helpful or contributed to you solving your problem, you can mark more than one accepted solution.
Accepting a solution will mark your question as resolved and will make it easier for others in the Community to find valuable content and answers without having to read through an entire topic.
Marking a reply as a solution will make it easier for others who have a similar issue to find. It is also a great way of saying “Thank you!” and recognizing who helped you.
To mark a reply as the solution, locate the check mark “Accept Answer” by the reply that helped you solve your issue.
Not only will you mark the reply as the solution, your question will also be marked as having an accepted answer.
Now that you know how to accept a solution, go out there and make this community great!
Mikael Sandberg
Jira Ninja/Atlassian Wizard
Arthrex
Seattle WA
2,047 accepted answers
8 comments
