Expanding scorecard Easy Fix to all fields and scorecards in Compass
We are excited to announce that we have expanded the UX to update component fields inline inside the Scorecard drawer - a feature we call “Easy Fix” - to support custom fields and custom scorecards in Compass. This enhancement is designed to streamline the process of fixing failing criteria on Compass Scorecards, making it more efficient and user-friendly.
With Easy Fix, users can directly fix any failing criteria field from the Component x Scorecard drawer. This eliminates the need for multiple clicks and navigation through the UI, significantly reducing the time and effort required to maintain healthy scorecards.
Until now, Easy Fix has only been available on built-in fields and on built-in scorecards. Since its introduction, the Easy Fix feature has seen high engagement, and now we’re expanding it to work for all scorecards (including custom ones) and all fields (including custom fields).
Check it out:
0 comments
