Compass recently released an update to our Custom Webhooks for Compass app to support the Incident event type. Using this feature, you can now create a Custom Webhook to receive Incident events from ServiceNow.
This guide will walk through all of the set up steps needed in Compass and in ServiceNow to build this integration. Please note that some of these screenshots and instructions may be slightly different depending on your version of ServiceNow.
If you have not already, install the Custom Webhooks for Compass app and navigate to the Webhooks page.
On the next screen, add the following payload mappings for each field:
Incident state → .incident.state
Incident ID → .incident.id
Incident event URL → .incident.url
Incident severity level → .incident.severity.level
Incident severity label → .incident.severity.label
Incidents will appear on the timeline with their Priority from ServiceNow, i.e. "1 - Critical"
If you would prefer Incidents to appear only as an Icon on the component timeline, leave this mapping blank.
Incident event name → .incident.name
Incident event description → .incident.description
Start time → .incident.startTime
End time → .incident.endTime
Update sequence number and Last event update: leave these blank, as we will be using the provided defaults for these fields.
On the next screen, we will be mapping ServiceNow Incident states and their Priority level to their Compass equivalents.
Feel free to make any changes to these mappings to fit your individual workflow. If you have created any custom states in ServiceNow, be sure to map those values as well.
Suggested mappings for ServiceNow incident states:
New → Open
In Progress → Open
Resolved → Resolved
Closed → Resolved
On Hold → Resolved
Canceled → Deleted
Suggested mappings for incident Priority:
1 → ONE
2 → TWO
3 → THREE
4 → FOUR
5 → FIVE
On the next screen, we will be creating forwarding rules that will match services in ServiceNow to their corresponding Compass components.
For each component that you want to map, put the exact Name of the service in ServiceNow on the left, and its Compass Component ID on the right.
You can always come back to add or change component mappings at a later time. However, a component will not receive Incident events until it has a mapping on this screen.
Submit the form to save your webhook. Then click the Copy button on the main screen to copy the URL of your new webhook.
Navigate to System Web Services → Outbound → REST Message
Create a new global Outbound REST Message and name it "Compass Incident Webhook"
Paste the webhook URL that you copied from Compass as the Endpoint
After saving your new REST Message, open it again to edit it. View its HTTP Methods at the bottom of the page and click New to add a new HTTP Method:
Call this HTTP Method "Default POST" and set its HTTP Method to "POST"
Click the HTTP Request tab to view and edit the message body
"incident": {
"state": "${state}",
"name": "${incidentName}",
"description": "${incidentDescription}",
"id": "${incidentId}",
"url": "${url}",
"startTime": "${startTime}",
"endTime": "${endTime}",
"severity": {
"level": "${severity}",
"label": "${severityLabel}"
"serviceName": "${serviceName}"
Now that an outbound webhook message is configured, we need to add a Business Rule that will trigger this message to be sent whenever an Incident is created or updated.
Navigate to System Definitions → Business Rules
Create a new Business Rule:
Name it "Send Compass Webhook"
Set its Table to Incident
Check the boxes for Active and Advanced
In the When to run section, set it to run After any Insert or Update
Next, click on the Advanced tab to configure the custom code that we will execute:
Set the Condition to true
In the Script section, copy and paste the following script. This script will build your outbound REST message using attributes from your Incident, and call the webhook we created in the first step:
(function executeRule(current, previous) {
var responseBody;
var status;
var sm;
try {
// The name of your Outbound REST Message and Method must match exactly
sm = new sn_ws.RESTMessageV2('Compass Incident Webhook', 'Default POST');
// Set timeout of 10 seconds
sm.setHttpTimeout(10000);
// Build request body
sm.setStringParameter('severity', current.priority);
sm.setStringParameter('severityLabel', current.priority.getDisplayValue());
sm.setStringParameter('state', current.state.getDisplayValue());
// You must create a mapping of this service name to a Compass Component in the Custom Webhooks App
sm.setStringParameter('serviceName', current.business_service.name);
sm.setStringParameter('incidentId', current.sys_id);
sm.setStringParameter('incidentName', current.short_description);
sm.setStringParameter('incidentDescription', current.description);
var url = 'https://' + gs.getProperty('instance_name') + '.service-now.com/' + current.getTableName() + '?sys_id=' + current.sys_id;
sm.setStringParameter('url', url);
// Convert datetimes from ServiceNow
// See: https://www.servicenow.com/community/service-management-forum/how-to-convert-servicenow-ticket-created-date-in-to-iso-8601/m-p/390683
var original = current.opened_at.toString();
var dt = original.split(' ');
var f = dt[0].split('-');
var t = dt[1].split(':');
var event = new Date(f[0], f[1] - 1, f[2], t[0], t[1], t[2]);
var startTime = event.toISOString();
sm.setStringParameter('startTime', startTime);
if (current.resolved_at || current.closed_at) {
var endDate = current.resolved_at || current.closed_at;
var originalEnd = endDate.toString();
var endDt = originalEnd.split(' ');
var endF = endDt[0].split('-');
var endT = endDt[1].split(':');
var closedEvent = new Date(endF[0], endF[1] - 1, endF[2], endT[0], endT[1], endT[2]);
var endTime = closedEvent.toISOString();
sm.setStringParameter('endTime', endTime);
} else {
sm.setStringParameter('endTime', '');
// Send request
response = sm.execute();
responseBody = response.haveError() ? response.getErrorMessage() : response.getBody();
status = response.getStatusCode();
} catch (ex) {
responseBody = ex.getMessage();
status = '500';
}(current, previous));
Save your new Business Rule
Now whenever an Incident is created or updated in ServiceNow, it will send a webhook message to Compass. As long as a Compass component is correctly mapped to a service name in ServiceNow, it will receive Incident events on its timeline.
Please reach out to Compass Support if you have any difficulties following this guide or setting up your Incident webhook!
April G
2 comments
