Ability to ignore criterion errors on scorecards?
Joshua W
October 10, 2025
I'd like to have a scorecard that verifies that components have populated all of the custom fields which apply to them. We have different custom fields on different types of components. My current scorecard includes criteria for ALL the custom fields - so on components that don't have some of the custom fields, there are errors when evaluating the criteria, and the component fails on those criteria.
It would be very helpful, when defining a criterion on a scorecard, to have a checkbox to choose "Pass on error", so that you can tell the scorecard to count it as "passing" for a component that the custom field doesn't apply to.
Tomislav Tobijas
Hey @Joshua W ,
Yeah, there's no built-in option or checkbox like "Pass on error" for a criterion if the field is missing or if there's an error evaluating it (as far as I know).
I mean, each custom field criterion is only available for component types that include that field. You should be able to determine which component types a custom field appears on by editing the custom field settings.
As for feature requests related to this, I haven't managed to find any open ones.
What you can do is to reach out to Atlassian Support and discuss this requirement with them, and their team can raise a new suggestion based on that. (on which you can then vote and watch it for updates) 👀
Tobi
Enrique Serrano Valle
October 22, 2025
A feature request has now been logged for this: https://jira.atlassian.com/browse/COMPASS-171
Like Tomislav Tobijas likes this
Tomislav Tobijas
@Enrique Serrano Valle cheers for the info! 🙌
