Using CSV import to update my components seems to have broken the connection to GitHub. I would like to be able to update via CSV and still have the GitHub aspects working.
The steps I took:
1) I imported all repositories from GitHub as components
2) I wanted to bulk update components and see you cannot do this from the UI, so I followed the approach defined here: Update components using a CSV file
3) I ensured that the only columns in my file were
name | type | lifecycle stage | owner team |
4) I imported via CSV to the correct names and types, defining the lifecycle stages and owner teams.
5) I got a warning that 20 / 130 repositories failed to import. Log shows:
Failed to import REPOSITORY_NAME: Invariant Violation: 5 (see https://github.com/apollographql/invariant-packages)
6) It seems they all imported successfully as all the metadata I added is visible, but the GitHub connections seem to be lost. No repository URL and GitHub deployments are not showing.
7) Attempted to reimport from GitHub but met with "Repository already imported'.
Hi there 👋
I guess this happens because the CSV import process in Compass performs a full metadata overwrite, not a merge.
When you re-import components via CSV, any existing GitHub connection metadata (like links.repository.url) can get wiped out.
Here’s how you can fix or avoid it:
🧩 1️⃣ Restore GitHub connection manually
For each affected component:
If you have many components, this is tedious — but it’s currently the only fully reliable way to restore connections.
🧩 2️⃣ Prevent future disconnects (best practice)
Before performing bulk CSV imports, include the repository link field in your CSV:
name |
type |
lifecycle stage |
owner team |
repository url |
component-x |
service |
GA |
backend-team |
This ensures Compass doesn’t wipe the link on update.
🧩 3️⃣ “Repository already imported” fix
If Compass blocks reimport saying “Repository already imported”:
This clears the old association and allows a clean re-link.
If you manage lots of components, you can also use the Compass API for bulk updates instead of CSV.
It supports partial updates without breaking existing integrations.
Hi Ali, thanks for your reply.
1) This is very tedious with 150+ repositories so not really viable
2) This must be a bug as the Update CSV page states:
If you remove a field name and its corresponding values from any component, that information won’t change on the existing component - because it hasn’t been included in the CSV file.
By removing repository url it shouldn't have wiped out the data.
I will start again from scratch, link to GitHub to retrieve the components and retain the URLs this time, but this should be fixed for future users..
@Oli ,
You're right that this should work as described in the documentation that you have linked and omitting a repositories column altogether should not modify existing repositories. However, as you're pointing out, the current code would remove links that aren't part of the CSV.
Our engineers have been notified of this situation, but in the meantime, some of the mitigation strategies that @Ali Umut Terzi has mentioned (such as providing the repositories in the CSV or using the bulk API instead) could help.
