×HI Team,
am working on the compass github actions integrations, i can able to configure the build success rate and all other metrics except the "Change failure rate"
1)need suggestion on what is this metric ?
2)is this metrics related to deployment failure or service failure in production
in the below curl command
need inputs on this
any suggestions on this ?
curl --request POST \ --url https://prospermarketplace.atlassian.net/gateway/api/compass/v1/metrics \ --user "$USER_EMAIL:$USER_API_KEY" \ --header "Accept: application/json" \ --header "Content-Type: application/json" \ --data "{ \"metricSourceId\": \"ari:cloud:compass:630bb765-afa4-4c7b-93f8-a40925b25929:metric-source/973a5e36-3928-4b46-afee-0910ab5551f9/cf2bf18b-85ce-4753-bb24-15ff46e649aa\", \"value\": $METRIC_VALUE, \"timestamp\": \"$(date -u +'%Y-%m-%dT%H:%M:%SZ')\" }"
what is this metric value ? how it is calculated ?
Hi @Sridhar Ravula and welcome to the Community
Change failure rate
The percentage of changes that failed to apply or impacted the component. Based on the last 28 days.
$METRIC_VALUE is the value that you want to pass in. For this metric, it is a numerical value that represents a percentage.
Here is some additional documentation: https://developer.atlassian.com/cloud/compass/components/push-metric-values-using-a-curl-command/
, specifies the value you want to push for your component’s metric. The value is a number, for example,123
or4.56
. In this line, replace$METRIC_VALUE
with the numerical value for the metric.
If you don't find that metric useful, you can remove it from the component and/or scorecard.
