yaml component dependencies not showing
prashant
February 7, 2024 edited
in one of my component's (c1) compass.yml i added dependency to another (c2) component. but its not visible in dependencies page for component c1 or c2
Alie Sesay
March 28, 2024 edited
Hi Prashant,
I apologize for the delayed response and any inconvenience it may have caused.
To further investigate the issue, could you please provide the following information:
1. After adding the component's dependency in the compass.yml, did you happen to access the config-as-code tab?
2. If yes, please confirm whether you received a confirmation that the compass.yml file was synced successfully, as illustrated below.
3. If not, please double-check the structure of your compass.yml file to ensure it matches the required format outlined in the reference below:
https://developer.atlassian.com/cloud/compass/config-as-code/structure-and-contents-of-a-compass-yml-file/
4. If the issue persists, please let me know so I can create a support ticket to help resolve the issue.
Alie
