Performance (Speed) of databases
Stefan Froehlich
May 14, 2024
Hi all,
I am curious, because I couldn't really find any other topic about this subject. We are testing databases with a few different use cases and we experience a very noticeable delay in opening the database, even though its practically empty or has at most 40 to 50 entries.
If I compare this to for example Notion, there the database shows up instantly.
I have tried this now as well on my personal test instance and I see the same delay as well, so I don't think its related to our instance.
I have uploaded an example here: https://app.screencast.com/2ZK4j9PN12sJm
Stefan
5 comments
Alexander Pappert
May 17, 2024
yes, sometimes databases really need long to load
don't know if it is the content load itself, or as I think more the loading time of header. because also when I scroll the header needs time to be reloaded at its new position.
Olie Ryan-George
I agree with this. I've got a dataset with hundreds of records which shouldn't be much in the grand scheme of things. Whenever I scroll, there is a few seconds of loading time which makes it hard to scroll through to find a row in its context
Like • 2 people like this
Stefan Froehlich
July 26, 2024
Hi @Rachel Li mind chiming in to this question?
Thank you,
Stefan
Like • Emoke Mozesne Csikos likes this
Rachel Li
July 31, 2024
Hey @Stefan Froehlich thanks for tagging me here, the team is looking into the issue. We'll message here once we have updates!
Hi @Stefan Froelich  Thank you for raising this important concern.
I experience a generic slowness across the entire database. However, I can see some noticeable improvement in the past few days.
@Rachel Li are there any known limitations on the size of the databases, or any recommendations for the structure? Maximum number of rows/columns/views?
Also, I have seen mentions of exact sizes as limits (5MB?) - how do you measure the size of the database?
Thank you.
Alex Hixon
August 8, 2024
Hi team!
We've landed some improvements which should render recently viewed databases almost instantly.
We'll be working on improving load times for newly created databases and scrolling performance soon.
Alex!
Senior Software Engineer, Confluence Databases
Like • 3 people like this
Stefan Froehlich
August 28, 2024
Thank you Alex, I can confirm performance definitely improved here on my end.
Gonchik Tsymzhitov
Thank you!
