is it possible to select more than 1 tag a field?
Alexander Pappert
April 10, 2024
example:
I created tags, to which component the function described in the database row is related
Tag1: motor
Tag2: valve
But it can be, that the function described in the database row is related to motor & valve, so I would need to assign 2 tags there.
A workaround would be co create an additional tag that combines the 2 others, but then when someone needs to filter he needs to know this and filter for both tags, so that he gets all information.
1 comment
Alexander Pappert
April 10, 2024
after searching a bit, I found it
Like 3 people like this
