Database does not allow to paste anymore
Martin Vali
My database does not allow to paste or delete anymore.  It has 299 rows
When I create new database, I can do all things.
Does database have limits?
2 comments
Tomas Vaicekauskas
Hello Martin,
I had the same issue, check if your database structure is not locked.
Like 2 people like this
Martin Vali
Thanks, It fixed the problem, but I like to keep the structure locked. Bug i presume
Kristian Klima
I locked the structure and could add and edit at content at will.
It locks the structure, not the content. In other words, you cannot add new columns, but you can add entries.
Rebecca Dai
January 7, 2025
Hi @Martin Vali @Tomas Vaicekauskas
Thank you for reporting the issue and sorry for the inconvenience. A fix has been deployed to allow copy and paste on a database with lock structure. It will land on production momentarily.
Note there is a separate bug that pasting allows creating new fields on a database with lock structure. This bug will be addressed soon. Thank you!
Kristian Klima
Hi @Martin Vali
I have over 1200 pages (rows) in my Database so that doesn't seem to be an issue.
When pasting content, you just need to make sure that you're pasting content that matches the field.
For example, in my Page Link column, I could only paste a page's URL. Trying to paste text resulted in
Similarly, you cannot paste content into cells the content of which is autogenerated - for example, I could not paste into my Description field which is generated from an Excerpt.
Pasting into a text field was not an issue.
I'd also check your permissions for the database etc.
Martin Vali
Hi @Kristian Klima
It's currently connected to lock structure function. It worked fine until now.
I contacted the support also, and they confirmed, that it's a bug
Like Kristian Klima likes this
