×Hi,
currently we use miro, but since Confluence now got Whiteboards, I would prefer 1 solution.
Is it possible, or planned, to migrate miro whiteboards to Confluence whiteboards?
Hi @Alexander Po. ! Came across this post and wanted to let you know you can now import Miro boards directly into Confluence whiteboards using the Miro importer! Learn more about it here. The coolest part of this importer (IMO) is that you can edit elements from your Miro boards IN Confluence whiteboards. Most tools only allow PDF or PNG static imports. Happy importing!
Thanks for posting @Jena Slezak
I did a quick test and some arrows as a first example were a little ambiguous in terms of direction, these would need a tidy up from end users if they used this.
I will continue testing other elements.
Any plans to further develop this plugin or will this be it in terms of how it works?
Unfortunately, at the moment, Confluence only supports importing images of your whiteboard from Miro. You can refer to this doc: https://support.atlassian.com/confluence-cloud/docs/import-miro-boards-in-confluence-whiteboards/
You can keep updated with the roadmap of Confluence here: https://www.atlassian.com/wac/roadmap/cloud?selectedProduct=confluence&
Hope it helps 🙌
ok, lets wait for an import tool, only images are not really good.
Hi @Liam - DevSamurai, is there any update regarding the migration of Miro to Confluence Whiteboards?
I couldn't find a roadmap item and in general, the Whiteboards roadmaps looks kinda empty.
Hi @Andreas Freund, welcome to the community
As I looked around, seems like there's no plan for this feature from Atlassian in the near future.
The only possible way right now is to import your Miro boards as an image or PDF file.
Some people have the same issue here: https://community.atlassian.com/t5/Confluence-questions/How-to-import-a-Miro-Board-to-Confluence-Whiteboards-beta/qaq-p/2431056
I'll let you know if there's an update on this.
Cool, thanks a lot 😊
