Hi everyone! Nat here from the Fabric team.
We’d love to get your feedback on some concepts and ideas that we have for using Fabric and Jira.
We’re currently exploring how Fabric can support many parts of the agile planning process, from high-level ‘macro planning’ through to team-level planning activities like sprint planning, backlog prioritisation and tasking out.
Our ask: Watch the video below 👇 and leave your feedback in the comments.
We’d love to hear from you on:
When and where in your workflow you would use these features?
Why would you use them over your current solution? Why would you not?
What would you hope that these features could do?
Are there other features of functionality you hope Fabric can build?
How would prioritise these concepts against each other? Which ones do you find more valuable than others? Why?
Cheers!
Nat | Fabric design lead
We use visual collaboration tools online for user story mapping, so a healthy relationship between Fabric and Jira would be valuable. At first blush, we see 'show child issues' potentially making our user story maps easier to scan. On the theme of keeping Fabric tidy, it might be nice to have some way to gather sticky notes by a value, like a keyword or votes. Or even asking Fabric to generate themes and group notes by them based on note contents. The bulk operations also seem like a nice-to-have and would help with organizing things by labels/keywords.
'Import Jira issues' could also be helpful for us for user story mapping in situations where we have stories already on a board (it happens), but in principle seems like a no-brainer. It saves work on data entry, helps avoid duplicates and conflicts, and presumably would bring in all the information you'd care to see from your board (i.e., assignee, status, etc.).
I hope this helps!
Christian
Nice updates Nat and team. Definitely focusing on the differentiators and adding value to the Jira experience.
- Bowan
@[deleted] great thoughts! Thanks. Really love the idea of having a way to group ideas/work items. We'll have to have a think about that.
Epic feedback, @Bowan Spanbroek 🙏 Some questions:
The bi-directional sync is essential for Smart Categories - wouldn't use it without that. We would not use it if the syncing had issues or was slow.
What does "bi-directional sync" mean for you here? Just that when an issue was dragged into a Smart Section, it immediately updated that ticket in Jira + on the Smart Link view of the ticket in Fabric?
Both the connections and the smart categories would need to have a clear way to turn to manual sync (press a button) and then making it automatic should be something you turn on deliberately to avoid messing up boards.
When you talk about "manual sync", would that be where a user draws connections and defines a relationship to add to the ticket in Jira, BUT, it only adds that link in Jira when the user says they want it to be updated in Jira?
If you were going to build a backlog prioritisation smart category could you perhaps make it a seperate 'type' or board with a different UI treatment as it's a really specific use case.
Do you have any thoughts on what you'd hope a separate board with different UI treatment could look like?
Bulk Import- IMO this needs to come first as it enables the other features.
For how you search for Jira issues to import, would you expect to use JQL or just a simple search where you type words related to what you're looking to import? ccc: @Christina Ristevski
Thanks again for the feedback!
On that thread of searching Jira issues to import, how often do your teams use saved filters in Jira?
Thanks @Bowan Spanbroek
Re; real-time sync, we'd definitely expect for any link created in Fabric to update in Jira in almost real-time.
Will it include advanced roadmaps hierarchy when showing child issues?
Thank you for this overview @Natalie Johnson and thank you for the mention @Jonno Katahanas
@Svajunas Gaina great question. I'd assume we'd respect any form of parent-child relationship, which would include those in Advanced Roadmaps. @Natalie Johnson (design lead), our eng feature lead and I will need to dig into this more on our side.
Thanks for the epic feedback, @Andrew Kendris !
Visualize Child Issues: Issues can be dragged and dropped from one parent issue to another and have that sync back to Jira
Love this idea (as well as your others, too). We've played around with something related to this in the past. Might be worth us going a bit deeper.
Importing Issues, if there is a way to write a JQL script within the Fabric interface so users can get what they need without searching for individual tasks
We have some people working on this now! We'll keep you posted when it's available. cc: @Christina Ristevski @Mario Nebl @Eden Gorton
Are there other features of functionality you hope Fabric can build To avoid users needing to go down to the toolbar on the bottom to grab items, it would be awesome to have keyboard shortcuts that automatically add those items to the board where the mouse pointer resides (text box, post-its, lines, etc.)
We've been planning to do this. Haven't got round to yet. Should hopefully have in near future.
Thanks again for the awesome insight!
