We are using a whiteboard to coordinate the work of multiple people. Going from stickies to Jira issues has been very helpful, and it's helping us move more of our process into Jira. The problem we are having is that once we have a Jira ticket shown on a whiteboard as a card, the assignee is not shown. This is causing confusion as we cannot tell which issue is applied to which person.
How do we show the assignee on a Jira Issue Card?
Solved! Go to Solution.
Customizability would be great, but it might be easier to simply match Jira's default. Issue type, priority and story point estimate would be valuable, but not as necessary as assignee in our use case, as I suspect it will be for many others. The purpose of the whiteboard is collaboration, and if you're obscuring the assignee things get opaque and unmanageable.
Perhaps it would be possible for you to easily add assignee to the current view to solve the existing problem and consider the larger task of customization to add functionality later?
That thinking makes sense. We've heard some asks for assignee, too. At some point we'll probably move towards providing customisability.
cc'ing in our designer @Daniel Simmonds who's been having a look at adding more meta data into the Jira cards.
Thanks. @Daniel Simmonds feel free to let me know if you need any additional insight into our use case. For what it's worth we feel strongly that this is needed, and in an ideal world you guys could quickly implement just assignee and not get into a larger, more time consuming, less valuable (in our opinion) project around customizability.
Hi @Matt Richards thanks for the feedback, I've actually heard this come up through a few interviews in similar use cases to yours. Yes, I am exploring what cards will look like with different metadata, starting with the assignee.
Posting this on behalf of @Daniel Simmonds as his media upload is playing up.
Example below of what it could like showing the assignee avatar on a Jira Smart Link. This is the same approach to how assignee is shown on a Jira issue in a Jira board.
Looks great to me! What are the chances this will be implemented soon?
Figuring specifics out. But hopefully over the coming couple of months. We're currently heads down getting the Beta out the door, including moving whiteboards into the content tree, global create, recents, etc.
We can update with progress as soon as we know.
I appreciate the insight. The sooner the better. This is a big one considering the overall positioning of the product!
