Using panels on a page is a great way to structure your page content to make it look less cluttered and more professional. One great feature of the code block macro that I wish was part of the panel macro is the ability to collapse the content section.
For instance, you may have a page in Confluence that serves as a dashboard of sorts with graphs, Jira macros, and other important metrics that are structured using panels. It would be nice to have a way to maybe collapse some of those panels to save some screen real-estate and prevent having to scroll. Oh well, I guess it can't be done. Tough luck!
Wait! Don't leave. I was just kidding! :) We can easily create a user macro for this to give us that ability. The code for this is below along with some screenshots of how it looks on the page and how to set it up when editing the page. If English is not your native language you can easily change the expand/collapse text by editing lines 18 and 19 to your liking. Enjoy!
Macro Name:
collapsible_panel
Macro Title:
Collapsible Panel
Description:
Any panel macros placed within this macro that have a Panel Title will be collapsible.
Macro Body Processing:
Rendered
Template:
## Developed by: Davin Studer ## Date created: 05/31/2018 ## @param ID:title=Panel ID|type=string|required=false|desc=Optionally provide a unique id to surround the panel(s) (no spaces). ## @param Start:title=Start Collapsed|type=boolean|required=false|desc= ######################################################################## ## Use the given ID if present otherwise generate one. The reason for ## ## this is so that we can target each user macro distinctly if this ## ## is included more than once per page. ## ######################################################################## #if( $paramID && $paramID != "" ) #set( $id = $paramID ) #else #set( $id = $action.dateFormatter.calendar.timeInMillis ) #end #set( $expandText = "Expand panel" ) ## Change this to fit your desired verbiage/language #set( $collapseText = "Collapse panel" ) ## Change this to fit your desired verbiage/language <script type="text/javascript"> //<![CDATA[ AJS.toInit(function(){ // These are the CSS styles for this macro. It used to use a style element, but that was causing Confluence // to not keep the header bar at the top when you scroll the page. For some reason just putting style elements // in a user macro will cause the top bar to not remain static at the top of the page. var style = '<style type="text/css">#collapser-$id .panel.collapser-closed .panelContent {display: none;}\n#collapser-$id .panel.collapser-open .panelContent {display: block;}\n.collapser {float: right; cursor: pointer; margin-right: 5px;}\n.collapser-text {vertical-align: top; color: #3b73af;}\n.collapser-text:hover {text-decoration: underline;}</style>'; AJS.$('#main-content').prepend(style); ///////////////////////////////////////////////////// // This block is a mix of Velocity and Javascript. // // The Velocty variable will add Javascript to // // open or close the panel(s) within the macro // // depending upon what the user set. // ///////////////////////////////////////////////////// #if ( $paramStart == true ) AJS.$('#collapser-$id .panel .panelHeader').append('<span class="collapser"><span class="collapser-button expand-control-icon icon"> </span><span class="collapser-text">$expandText</span></span>'); AJS.$('#collapser-$id .panel').has('.panelHeader').addClass('collapser-closed'); #else AJS.$('#collapser-$id .panel .panelHeader').append('<span class="collapser"><span class="collapser-button expand-control-icon icon expanded"> </span><span class="collapser-text">$collapseText</span></span>'); AJS.$('#collapser-$id .panel').has('.panelHeader').addClass('collapser-open'); #end AJS.$('#collapser-$id .panel .collapser').click(function() { var panel = AJS.$(this).parent().parent(); // Get the panel for this specific collapser var open = AJS.$(panel).hasClass('collapser-open'); // Is it currently open or closed? if(open) { toggleCollapser$id(panel, 'close'); } else { toggleCollapser$id(panel, 'open'); } }); }); function toggleCollapser$id(panel, action) { if(action === "close") { AJS.$(panel).removeClass('collapser-open').addClass('collapser-closed'); AJS.$('.collapser-button', panel).removeClass('expanded'); AJS.$('.collapser-text', panel).text('$expandText'); } else { AJS.$(panel).removeClass('collapser-closed').addClass('collapser-open'); AJS.$('.collapser-button', panel).addClass('expanded'); AJS.$('.collapser-text', panel).text('$collapseText'); } } //]]> </script> <div id="collapser-$id">$body</div>
Davin Studer
Business Intelligence Engineer
Vancouver, WA
480 accepted answers
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
26 comments
