Hello!
I needed to install a Confluence instance for my internal testing but I wanted to use the Postgres database not the internal one.
First I had a look at the docker shipped by Atlassian:
https://hub.docker.com/r/atlassian/confluence-server/
I found a section about using external database but there was no examples. Of course I could create a docker with Postgres, create a Confluence database there, but it would take me more time than I wanted to spend on it.
Then I remembered that Idalko had a tool in Python for running dockers. I typed Idalko docker and got a link to this page:
https://hub.docker.com/r/idalko/atlassian-confluence
I was surprised, it is not a Python project anymore. It is already can be considered as a product.
Moreover there was an example how to run this docker with a Postgres database. Here is the example:
version: '3'
services:
confluence:
image: idalko/atlassian-confluence
environment:
- DISABLE_NOTIFICATIONS=TRUE
- CONF_ARGS=-Datlassian.plugins.enable.wait=300
volumes:
- ./data:/opt/atlassian/confluence/data
ports:
- 8090:8090
restart: always
confluencedb:
image: postgres:9.6
environment:
- POSTGRES_PASSWORD=secret
- POSTGRES_USER=confluence
- POSTGRES_DB=confluence
volumes:
- ./db:/var/lib/postgresql/data
restart: always
I created a docker-compose.yml file out of this code and ran the following code in the terminal:
docker-compose up
Then I opened a browser and connected to this url:
http://localhost:8090
I had a standard Confluence setup page. I configured the database:
Then I was asked a couple of other standard questions and I had a Confluence instance running with a Postgres database.
Also the Confluence home directory was mapped to the data folder and Postgres data to the db folder:
Amazing! I spent a couple of minutes to setup everything. Thank you Idalko!
Alexey Matveev
software developer
MagicButtonLabs
Philippines
1,577 accepted answers
10 comments
