Full speed embed! Introducing a new way to Smart Link
80 comments
Flavio De Souza February 9, 2022
This is nice and looking forward to see what is next.
Quick questions:
  1. Is there any chance that it will work with any other custom field type, other than rich text (aka paragraph)?
  2. Are you considering creating a new macro in confluence that allows populated a field (e.g. a specific table cell) with the content available at a specific custom field of an issue type?
  3. And if you also include a body where you can change the entire content by just changing the issue type number? This would allow us to create new pages/reports with less friction, thus potentially making the Confluence our repository for Experiment (A/B test) results.
Flavio
Lennon Liao
February 9, 2022
@D_M_Isca Awesome feedback about the excerpt! We will definitely consider that in our next iteration of the feature. 🙂
Like C_ Dicker likes this
Lennon Liao
February 9, 2022
Hi @Ryan Beller Which web browser are you using? Does this issue happen when you are using Chrome?
Lennon Liao
February 9, 2022
Hi @Elizabeth Sprouse Only users with permissions to that page will be able to access it (you won't have to worry that unauthorized people will have access to that page). 🙂
Like Elizabeth Sprouse likes this
Ryan Beller
@Lennon Liao I was using Chrome. I also tried Chrome incognito mode with the same error. I can, however using the link in Jira (above the failed embed) to go over to Confluence and see the page using my current user/session. So I know it's not a permissions issue.
Like 2 people like this
Genovéva Horváth February 9, 2022
Great new feature! Will definitely use it ;) Thank you!
Like Lennon Liao likes this
Talha
February 10, 2022
Thank you for adding this feature.
Wouter
Great feature, we are already using it.
But we are still really disappointed in your Product Team...
Why do you force tech people to use 'smart links' by default? In 99% of the cases, our tech team wants to show full URL's in specs and comments. Why is this discussion JRACLOUD-72429 still not solved?
Like Stavros_Rougas_EasyApps likes this
Lennon Liao
February 10, 2022
Thanks for the feedback on the embed feature @Wouter🙂
As for smartlinks by default, rest assured that we're hard at work on this. We hear you loud and clear and are coming up with solutions to address your pain points. The latest updates would be available on JRACLOUD-72429
Like Wouter likes this
Arby Leon March 10, 2022
@Lennon Liao
We were using this ok and then it stopped working. Is there an issue with this implementation?
Lennon Liao
March 10, 2022
Hi @Arby Leon  This feature should be working as per normal. Can you describe what is the issue you are currently experiencing? Thanks!
Badana Shanmukha Teja March 14, 2022
This looks good feature, but I'm unable to see this option, how to get this inline options, please assist.
we are using confluence 7.15.0 server version.
Daniel DuBravec
Will this be available for Data Center?   Is so, what would the timeline be.   Thanks.
Lennon Liao
March 14, 2022
Hi @Badana Shanmukha Teja and @Daniel DuBravec This feature is only available on Confluence Cloud. We currently have no plans to support this on Server and Data Center, but will keep you posted if anything changed. Thank you.
Like Badana Shanmukha Teja likes this
Arby Leon March 14, 2022
@Lennon Liao here is the error message we're getting:
Unable to display page content
You can still view this page in Confluence by clicking here.
Ok, if this option is available in cloud version, then is there any possibility to get this feature through some 3rd party plugins? If yes, please let us know
Ben Buck
March 17, 2022
Hi @Lennon Liao this is a useful addition, but please please please enable us to define the default behaviour. I would estimate that 90% of the time I past a URL into a Jira ticket I want it to show the URL and not convert to a smart link.
What I want is to be able to specify the default behaviour of a smart link to be "Display URL"
I feel like all the effort spent adding this feature is catering for 10% of my needs whereas 90% of my time I spend CTRL-Z the smart link to get the URL back.
Lennon Liao
March 18, 2022
Hi @Arby Leon What web browser are you using (Chrome, Safari etc)? Often times, the root cause is that your web browser has blocked 3rd-party cookies which results in that blank screen. You can try to switch your settings to unblock 3rd-party cookies and see if that solves the problem. Happy to have a call with you to discuss further.  Thanks.image.png
Flavio De Souza March 21, 2022
Hi @Lennon Liao
Did you have the chance to check my comment on Feb. 9th?
Arby Leon March 21, 2022 edited
@Lennon Liao, using Chrome 99.0.4844.74 on MacOS 10.13.6. I'll check and get back to you.
Thank you in advance for the help.
@Lennon Liao, once I activated the 3rd party cookies it started functioning again. This most likely must have been caused by a chrome update. Thank you!
Lennon Liao
March 21, 2022
Hi @Flavio De Souza Sorry I missed your earlier message. We currently don't support those 3 workflows that you described. However, we will definitely take these suggestions into consideration as we explore new ways to make our Jira and Confluence integration work even better. Would love to discuss this in detail with you and better understand your workflow.
Maximilian Floß March 30, 2022
@Lennon Liao Is this feature with embeded smart links for all Cloud instances already available?
In my CloudSite I do not see the option:
Maryam Sharifzadeh March 30, 2022
Thank you but every time it shows me an error in the loading file, do you know why It happened?
Maryam Sharifzadeh March 31, 2022
Hi @Lennon Liao thank you for your clear explanation. we used this way to embed our Google Drawing, but now I see an "unable to load file" error. and just me in our organization see this error :/ It doesn't happen in the incognito tab. I use chrome. do you know what is the problem?
