Hello!
In this article, we will learn how to maintenance with python and Confluence REST API and set script into your CI e.g. Atlassian Bamboo. Also, it is very easy to automate it and extend functionality.
Nowadays, so many Confluence instances have enabled function collaborative editing or long time did not maintenance. For example, in our instance, DB backup in text format has been decreased by ~ 16%.
For more comfortable use raw Rest API I’m using python module with name atlassian-python-api. Hence code is so small and easy.
def clean_pages_from_space(confluence, space_key): """ Remove all pages from trash for related space :param confluence: :param space_key: :return: """ limit = 500 flag = True step = 0 while flag: values = confluence.get_all_pages_from_space_trash(space=space_key, start=0, limit=limit) step += 1 if len(values) == 0: flag = False print("For space {} trash is empty".format(space_key)) else: for value in values: print(value['title']) confluence.remove_page_from_trash(value['id'])
Feel free use this full example in script: https://github.com/atlassian-python-api/atlassian-python-api/blob/master/examples/confluence-trash-cleaner.py
Of course, in this use case we need to have some anchor for determine how old draft we should remove it
Therefore I am using variable
DRAFT_DAYS = 30
def clean_draft_pages_from_space(confluence, space_key, count, date_now): """ Remove draft pages from space using datetime.now :param confluence: :param space_key: :param count: :param date_now: :return: int counter """ pages = confluence.get_all_draft_pages_from_space(space=space_key, start=0, limit=500) for page in pages: page_id = page['id'] draft_page = confluence.get_draft_page_by_id(page_id=page_id) last_date_string = draft_page['version']['when'] last_date = datetime.datetime.strptime(last_date_string.replace(".000", "")[:-6], "%Y-%m-%dT%H:%M:%S") if (date_now - last_date) > datetime.timedelta(days=DRAFT_DAYS): count += 1
print("Removing page with page id: " + page_id)
confluence.remove_page_as_draft(page_id=page_id) print("Removed page with date {}".format(last_date_string)) return count
That’s all. I hope it helps for easy cleanup your Confluence. Next time I will show how to clean page versions, attachement versions. Because of these use case will reduce a lot of disk usage.
P.S. Let's set into CI system for delegate to other team mates.
Gonchik Tsymzhitov
Gonchik Tsymzhitov
Solution architect | DevOps
Cyprus, Limassol
175 accepted answers
Learn more
10 comments
