Hi All - This is a great method no doubt but author has not provided any guidelines or instructions which can be followed correctly and I have hit a wall in even starting it.
1. I can't even derive the same color coding that Alana used, and now that she has stopped responding to queries or doubts on this post, so anyone else can help me derive the same color coding like what she has shown in her sample? 2. Also, was any one able to derive this form of testcase and test management tables and charts as she has described? Her method is void of any detailing/instructions so wasn't much help anyway. All I learnt from her method is that this is possible but how is not mentioned in her.
A realistic form of help would be very kindly appreciated.
@Ceci Briozzo - I have the same situation like yours too. All testcases for a use case in 1 page and need for reporting around all their status on top of page using some chart.... but alas no luck so far. :D Were you able to make any progress for your problem, could you help me too?
the initial post from @Alana Fernando is really great but as a beginner it would be really nice to have a template ... is really nobody able to share it ???
Hi there, Can we integrate JIRA for requirement traceability with Confluence test case management plugin. I mean link test cases in Confluence with requirements in JIRA. Thanks.
If you're using the Jira/Confluence Cloud, have you considered using the Confluence Database for your needs? It allows linking Confluence with Jira, ensuring real-time synchronization of information.
42 comments
