500 Error on Confluence Startup
shredtechular
May 24, 2013
I am unable to start up our Confluence instance. Well, we get a 500 error on the home page after starting up at least. The error we see in the web page is:
exception
com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NullPointerException
	com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149)
	com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112)
	com.atlassian.confluence.web.filter.LanguageExtractionFilter.getLocaleManager(LanguageExtractionFilter.java:63)
	com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:48)
	com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:25)
	com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:44)
	com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65)
root cause
	com.atlassian.spring.container.ContainerManager.getComponent(ContainerManager.java:33)
	com.atlassian.confluence.util.LazyComponentReference$Accessor.get(LazyComponentReference.java:44)
	com.atlassian.util.concurrent.Lazy$Strong.create(Lazy.java:85)
	com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:321)
	com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143)
In the catalina.out log file we get:
May 24, 2013 8:57:45 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server} Setting property 'debug' to '0' did not find a matching property.
WARNING: [SetPropertiesRule]{Server/Service/Engine} Setting property 'debug' to '0' did not find a matching property.
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host} Setting property 'debug' to '0' did not find a matching property.
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'debug' to '0' did not find a matching property.
May 24, 2013 8:57:45 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8090
INFO: Initializing Coyote HTTP/1.1 on http-8443
May 24, 2013 8:57:45 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 569 ms
May 24, 2013 8:57:45 PM org.apache.catalina.core.StandardService start
INFO: Starting service Tomcat-Standalone
May 24, 2013 8:57:45 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
2013-05-24 20:57:46,831 INFO [main] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 5.1 [build 4215 based on commit hash 27aa6aff3fb0e9e5138a84da80ecdaa533a08846]
May 24, 2013 8:57:56 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8090
INFO: Starting Coyote HTTP/1.1 on http-8443
May 24, 2013 8:57:56 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 10290 ms
May 24, 2013 8:57:56 PM org.apache.catalina.core.StandardHostValve custom
SEVERE: Exception Processing ErrorPage[errorCode=500, location=/500page.jsp]
    at com.atlassian.spring.container.ContainerManager.getComponent(ContainerManager.java:33)
    at com.atlassian.confluence.setup.sitemesh.PluginDecoratorMapper.getPluginAccessor(PluginDecoratorMapper.java:74)
    at com.atlassian.confluence.setup.sitemesh.PluginDecoratorMapper.getDecorator(PluginDecoratorMapper.java:23)
    at com.opensymphony.module.sitemesh.mapper.AbstractDecoratorMapper.getDecorator(AbstractDecoratorMapper.java:45)
    at com.opensymphony.module.sitemesh.mapper.InlineDecoratorMapper.getDecorator(InlineDecoratorMapper.java:41)
    at com.atlassian.confluence.util.profiling.ConfluenceDecoratorSelector.selectDecorator(ConfluenceDecoratorSelector.java:59)
    at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:83)
    at com.atlassian.confluence.util.profiling.ProfilingPageFilter.doFilter(ProfilingPageFilter.java:44)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:71)
    at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
    at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:44)
    at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
    at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
    at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:438)
    at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
    at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
    at org.apache.catalina.core.StandardHostValve.custom(StandardHostValve.java:421)
    at org.apache.catalina.core.StandardHostValve.status(StandardHostValve.java:342)
    at org.apache.catalina.core.StandardHostValve.throwable(StandardHostValve.java:286)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
    at java.lang.Thread.run(Unknown Source)
Can anyone help me with this?
Andrew
3 votes
Ruben Fernandez December 3, 2013
Hi, for me (had the exact error described above) solved it by fixing permissions. There were plugin directories under /var/atlassian/application-data/ which the user confluence could not even change to. I believe that SElinux has something to do here ... :)
Mike Sheehan January 12, 2018
This fixed part of my issue. I also had to use the next answer from Yilin Mo.
Like Ayan Satybaldinov likes this
shredtechular
May 31, 2013
Thank you for the response. We tried to clear plugin cache via that article, however, that was still unsuccessful. We ended up re-installing the program to fix the issue.
Yilin
May 26, 2013
Seems a plugin issue, maybe you can try to perform the procedure :
https://confluence.atlassian.com/display/CONFKB/How+to+Clear+Confluence+Plugins+Cache
In case issue persist, I would like to advise you to open a new support ticket for help.
ITMSD December 12, 2014
That did it for me, thanks!
