Hi, I am trying to add a background color for a space, i am using version 5.3 and using IE 9 as browser. I look at the conlfuence guide and follow instruction and recommendation from the comments. I tried looking at the style sheet and put css codes to put a color and still nothing happens. Any suggestions how to do this. Thanks.
I was able to change the background color by adding the codes below to (Confluence Admin > Stylesheet):
.aui-page-panel{
background: red;
However, this will not work if you are using documentation theme, and will only work if you are on Default theme.
Cheers.
@hossein toussi Hello mate , you can help me with smt , i try to set the color also to my macros like " info -macro " and i cant , could you help me plz ?
Thanks mate, I will keep the suggestion, for now, the team decided not to put colors on the background. thanks again
