Adding user to space using power script
Poojaa Sudhakaran
August 8, 2020 edited
Hello there,
I'm trying to build a code snippet using Power Script for Confluence for bulk addition for users to a Confluence space. Below is my code snippet for adding user "sample" to a space with key "TEST". This script always returns a false value and the user is not assigned to the space with the mentioned permission.
string loglevel = "WARN";
logPrint(loglevel, addUserToSpacePermission("VIEWSPACE", "TEST", "sample"));
 But after, adding the user to space manually, the below code snippet work fine in removing the user from space.
logPrint(loglevel, removeUserFromSpacePermission("VIEWSPACE", "TEST", "sample"));
 Could you please help me in adding user to space using the script?
Poojaa
Ivan Lima
September 1, 2020
Hey @Poojaa Sudhakaran , assuming you've got all the parameters correct, this should work just fine. The only reason I see that it doesn't work is that your user "sample" is also a member of a group that already has the VIEWSPACE permission.
Hope it helps.
IL.
