The HKLM path is generically:
HKLM\Software\Adobe\(product name)\(version)\AVGeneral\bValidateBytesBeforeHeader=dword:00000000
For example, to change the behavior for Acrobat 11.0, create a DWORD at this location: HKLM\SOFTWARE\Adobe\Adobe Acrobat\11.0\AVGeneral\bValidateBytesBeforeHeader=dword:00000000
The HKCU path is generically:
HKCU\Software\Adobe\(product name)\(version)\AVGeneral\bValidateBytesBeforeHeader=dword:00000000
For example, to change the behavior for Reader 10.0, create a DWORD at this location: HKCU\SOFTWARE\Adobe\Acrobat Reader\10.0\AVGeneral\bValidateBytesBeforeHeader=dword:00000000
Always change the product and version number in the preference path to match your installation. This method allows the PDF to display on machines you control.
Could you explain what this has to do with Confluence?
