I am attempting Advanced Search using the Confluence API, and I am experiencing the following problems.
(NOTE: When publishing this topic, the forum made changes to the HTML links below because it said they were invalid. I hope they didn't change them too much!!!)
If I surround two or more conditions in the URL with parenthesis, an error is returned
THIS WORKS (no parenthesis):
· http://wiki.intra.lutron.com/rest/api/content/search?cql=type=attachment&title="EODB"
THIS WORKS (parenthesis around each criteria):
· http://wiki.intra.lutron.com/rest/api/content/search?cql=(type=attachment)&(title="EODB")
THIS DO NOT WORK (parenthesis around BOTH criteria):
· http://wiki.intra.lutron.com/rest/api/content/search?cql=(type=attachment&title="EODB")
· {"statusCode":400,"data":{"authorized":false,"valid":true,"errors":[],"successful":false},"message":"Missing closing parenthesis near field (()"}
THIS DO NOT WORK (parenthesis around each and BOTH criteria):
· http://wiki.intra.lutron.com/rest/api/content/search?cql=((type=attachment)&(title="EODB"))
· {"statusCode":400,"data":{"authorized":false,"valid":true,"errors":[],"successful":false},"message":"Could not parse cql : ((type=attachment)"}
If I use more than one criteria, it seems that some criteria are not executed
· http://wiki.intra.lutron.com/rest/api/content/search?cql=type=attachment&title="EODB"&limit=200
· This returns 200 records (when it should return 0) because the titles were not filtered to only include the file titled "EODB".
· It seems that the type and limit were executed, but title was not
· Examples of the titles returned include:
· SeeTouchExample.pdf
· DEPRECATED_Application_(GUI)_Software_Release_Authorization.xlsx
· image2016-10-7 16:30:12.png
· http://wiki.intra.lutron.com/rest/api/content/search?cql=title="EODB"&type=attachment&limit=200
· This returns no records (which is correct), and all I did was swap the order of TYPE and TITLE
Wildcards do not seem to work:
· http://wiki.intra.lutron.com/rest/api/content/search?cql=title="EODB*"
· http://wiki.intra.lutron.com/rest/api/content/search?cql=title~"EODB*"
· Both of these return an empty set
· http://wiki.intra.lutron.com/rest/api/content/search?cql=title~"EODB"
· Returns 3 records, as expected
Please help…
Mike
Hi Mike,
Your major problem is that "and" in CQL is not the ampersand character (&), it is instead the word "AND".
Therefore the URL should look like this: http://wiki.intra.lutron.com/rest/api/content/search?cql=type=attachment+AND+title="EODB"
In this URL, the + is a replacement for the space character. You could use %20 instead if you'd like.
Thanks, Stephen. This helped some, but I am still having some problems.
Replacing "&" with "+AND+" solved the problem of "unable to use outer parenthesis" Thanks!
However, the line that you "corrected" for me was working as-is (meaning, it worked using "&") How was it able to work in that case?!?! And more confusing, my example below seems to show that I HAVE to use "&", at least with 'limit'.
THIS STILL FAILS:
http://wiki.intra.lutron.com/rest/api/content/search?cql=(type=attachment)+AND+(title~"EODB*ESR")+AND+(limit=200)
ERROR MESSAGE:
{"statusCode":400,"data":{"authorized":false,"valid":true,"errors":[],"successful":false},"message":"Could not parse cql : (type=attachment) AND (title~\"EODB*ESR\") AND (limit=200)"}
BUT THIS WORKS!!! (Doing it "wrong", using "&" instead of "+AND+"):
http://wiki.intra.lutron.com/rest/api/content/search?cql=(type=attachment)+AND+(title~"EODB*ESR")&(limit=200)
Ideas?
Best,
Mike
Hi Mike,
That's because limit is an additional parameter, not a part of CQL.
Here's the documentation for CQL: https://developer.atlassian.com/confdev/confluence-server-rest-api/advanced-searching-using-cql
Here's the documentation for the REST call: https://docs.atlassian.com/atlassian-confluence/REST/6.5.2/#content (you should click on "Search")
I would recommend installing the REST API Browser in your instance, it makes debugging REST calls so much easier: https://marketplace.atlassian.com/plugins/com.atlassian.labs.rest-api-browser/server/overview
So using &limit=200 is not wrong, it is an additional parameter and should therefore be that way. :)
Glad I could help! If you could click on the "Accept as Solution" button I would appreciate it!
Thanks for looking so hard! For anyone else who's curious, it's the checkmark button next to the answer :)
