Advanced analytics
paul whyton
May 16, 2023
Is there a way to see from a top level page which pages in the tree have been accessed/updated or which content has been added?
Teodora V _Fun Inc_
May 17, 2023
Hi @paul whyton
If you want to see a notification on the page tree or anything on the left menu bar, I'm afraid It's not possible. But you can always add a "Recently updated" macro on your Top level page, and when you open the page, you will quickly see what's changed in your content.
paul whyton
May 17, 2023
that sounds like it might work, will it look through the child pages or just the one the macro is attached to?
Nicolai Sibler
May 22, 2023
@paul whyton this works precisely if all your child pages are tagged with the same label - you can set that label in the macro parameters then.
Like paul whyton likes this
Aron Gombas _Midori_
June 13, 2023
The Better Content Archiving provides the Content Status List macro which accepts a CQL  query and can render you the table with the last edit/last view information of the matching contents.
You can add that to any page anywhere, even multiple times. See the middle section here:
If you want to get that list for the children (descendants) of the page with the ID=1234 then use this CQL:
ancestor = 1234
This query will match all children, grandchildren, etc. and list all those.
(Discl. this is a paid and supported app developed by our team.)
