we use custom macros from "script runner for confluence". But after a restart all custom script macros show "unknown macro XXX":
What ca I do?
When I update a existing macro, it works. But this is no solution.
Hi Yaniv,
after a update of the plugin it works.
Steffen
Hi Steffen,
Could you please open a support ticket so we can follow on?
https://productsupport.adaptavist.com/servicedesk/customer/portal/13
Rafael
Hi James,
Did you update to the latest version?
Rafael
We are using 5.2.4... We were able to fix the issue by disabling and then enabling the macro.
any resolution on this one? we are getting the same error
Hi Yaniv,
Did you update to the latest version of ScriptRunner for Confluence?
Rafael
