recently we updated confluence due to security alert to version 5.1.5. Sadly, all the links to jira issues in confluence went broke.
Since our confluence is running under open source license, here's the link to the page
https://confluence.opensource.anotheria.net/display/MSK/Change+Log
Previously the links would point to jira issue in the https://jira.opensource.anotheria.net instance. Now I only see
Message.
What have we missed?
Hi Leon,
have a look into your upm and search for the "Jira Macros" plugin.
Maybe this was de-activated during the upgrade? If yes, try to activate that.
Kind regards
André
Yeah, that was it. I opened add-on management (new name?) and jira was completly deactivated, activated it all.
Now I have "
I have similar problem after upgrade. Can you tell me how did you fix it ?
I use SSL certificate for jira and confluence. It’s setup on apache which is connected to tomcats using AJP.
I don’t have encryption directly on tomcat servers.
Everything was working fine and I didn’t have to import SSL certificate to establish connection between confluence and jira.
After upgrading confluence to 5.4.3 I get error:
com.atlassian.confluence.macro.MacroExecutionException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I imported apache SSL certificate to confluence with this tutorial https://confluence.atlassian.com/display/JIRA/Connecting+to+SSL+services
No I getting error:
com.atlassian.confluence.macro.MacroExecutionException: Unable to connect to site specified: Connection refused: connect
What else should I do ?
How did you upgraded?
fresh confluence install from scratch and export-import? Did you recreate the applink configuration after upgrade?
Most likely, no.
Depending on how you have performed the migration, you are running the application in a new tomcat and new JRE. Your certificate is not imported in the new keystore, isn't it?
Forgot to mention, we used is mostly to point our issues that have been fixed in a version in the change log. We basically just pasted the link into the confluence page and everything else worked auto-magically.
Learn more
