Anonymous user cannot view issues in JIRA issues macro in confluence
We can view only the first 4 issues on the page. But when we login to confluence we can see the results properly.
Please advise.
Hi Prachi,
Could you please confirm that JIRA allow anonymous login and permission to see the issues. You mentioned that anonymous can see the first 4, could you please let us know if the other issues that suppose to be listed comes from the same project? Or is there any restriction set for all the other issues.
Hope it helps.
Septa Cahyadiputra
Hi Septa, Yes, All the issues are from same project and the permission to browse the issue is set to "Anyone" for this project. Thanks
Just want to double check, do you configure application link as describe here: https://confluence.atlassian.com/display/DOC/JIRA+Issues+Macro
Yes, its configured as per the documentation. Note: We use version 5.1
