ApplicationPermissionException error when integrating Crowd with Confluence as a user directory
Puneet Baradia May 7, 2019
Hi
I am unable to login through local admin credentials in Confluence as well as through SSO after the import from Prod. to QA got failed and I got following errors in logs:
Caused by: com.atlassian.crowd.exception.ApplicationPermissionException: HTTP Status 403 – ForbiddenType Status ReportMessage Client with address "10.84.153.119" is forbidden from making requests to the application, confluence.Description The server understood the request but refuses to authorize it.Apache Tomcat/8.5.34
2019-05-07 03:56:22,294 WARN [Caesium-1-1] [impl.schedule.caesium.JobRunnerWrapper] runJob Scheduled job LaasPerformanceLoggingJob#LaasPerformanceLoggingJob completed unsuccessfully with response JobRunnerResponse[runOutcome=ABORTED,message='LaaS performance logging is turned off']
2019-05-07 04:00:00,012 WARN [Caesium-1-2] [impl.schedule.caesium.JobRunnerWrapper] runJob Scheduled job com.atlassian.confluence.plugins.confluence-periodic-analytics-events:confluenceDailyStatisticsPublisherJob#confluenceDailyStatisticsPublisherJob completed unsuccessfully with response JobRunnerResponse[runOutcome=ABORTED,message='Can't collect analytics.']
2019-05-07 04:01:22,294 WARN [Caesium-1-1] [impl.schedule.caesium.JobRunnerWrapper] runJob Scheduled job LaasPerformanceLoggingJob#LaasPerformanceLoggingJob completed unsuccessfully with response JobRunnerResponse[runOutcome=ABORTED,message='LaaS performance logging is turned off']
2019-05-07 04:03:39,230 ERROR [http-nio-8090-exec-3] [crowd.manager.application.ApplicationServiceGeneric] authenticateUser Directory 'New Crowd Server' is not functional during authentication of 'confluence-admin'. Skipped.
 -- referer: https://confluence-qa.cls.bcs.cnb/dologin.action | url: /dologin.action | traceId: 63052b5f8ad76606
2019-05-07 04:03:39,233 WARN [http-nio-8090-exec-3] [confluence.impl.hibernate.ConfluenceHibernateTransactionManager] doRollback Performing rollback. Transactions:
  ->[com.atlassian.confluence.user.DefaultUserAccessor.authenticate]: PROPAGATION_REQUIRED,ISOLATION_DEFAULT (Session #682686972)
2019-05-07 04:03:39,234 WARN [http-nio-8090-exec-3] [atlassian.confluence.user.ConfluenceAuthenticator] authenticate OperationFailedException caught while authenticating user <confluence-admin>.
com.atlassian.crowd.exception.runtime.OperationFailedException
        at com.atlassian.crowd.embedded.core.CrowdServiceImpl.convertOperationFailedException(CrowdServiceImpl.java:676)
        at com.atlassian.crowd.embedded.core.CrowdServiceImpl.authenticate(CrowdServiceImpl.java:76)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
2019-05-07 03:55:17,341 ERROR [http-nio-8090-exec-2] [crowd.manager.application.ApplicationServiceGeneric] authenticateUser Directory 'New Crowd Server' is not functional during authentication of 'confluence-admin'. Skipped.
 -- referer: https://confluence-qa.cls.bcs.cnb/dologin.action | url: /dologin.action | traceId: 5abaf2cbc612a239
2019-05-07 03:55:17,348 WARN [http-nio-8090-exec-2] [confluence.impl.hibernate.ConfluenceHibernateTransactionManager] doRollback Performing rollback. Transactions:
  ->[com.atlassian.confluence.user.DefaultUserAccessor.authenticate]: PROPAGATION_REQUIRED,ISOLATION_DEFAULT (Session #246236325)
2019-05-07 03:55:17,349 WARN [http-nio-8090-exec-2] [atlassian.confluence.user.ConfluenceAuthenticator] authenticate OperationFailedException caught while authenticating user <confluence-admin>.
Elifcan Cakmak
May 7, 2019 edited
Check out this documentation:
https://confluence.atlassian.com/jirakb/connecting-jira-to-crowd-throwing-applicationpermissionexception-301662474.html
You should try to add this IP address to the remote addressed of the application on Crowd like this:
After that you should be able to login with your crowd user.
Regards.
Hi Elifcan
Thanks for your response.
I already tried that solution but did not got any success as the error remains the same.
Elifcan Cakmak
May 8, 2019
It's interesting. Have you tried to restart confluence? Also it's not meaningful that you can't login with a local admin user. There is nothing about that in the logs. All I see is crowd related problems. What is the error? Are you sue that username and password correct?
We also encountered this issue and the problem was solved with the way I suggested.
This is the documentation for the other error you encounter: (crowd is not functional)
https://confluence.atlassian.com/crowdkb/crowd-user-authentication-fails-with-directory-x-is-not-functional-during-authentication-error-391086721.html
This suggests there may be network issues. I recommend restart crowd first and wait until it's fully started. Then restart confluence and see what happens.
Regards.
Puneet Baradia May 8, 2019
Yes, I tried restarting confluence.
I also tried restarting Crowd and then Confluence but that also didn't solved my issue.
Can you please suggest something new ?
Help us plant more trees
