×As you can see in the attachments, Atlassian Companion does not recognize the "xlsm" MACRO file. It is working pretty well as "xlsx" (no macro).
Nevertheless, I want to improve my excel file and Atlassian Companion is a limitation at the moment.
Could you please help me?
Many thanks!
Best,
Thiago
While the Companion app will open .xlsm in Excel just fine (when you click edit on the attachment), the Office Excel macro on a page is a different matter entirely.
Turns out you have to save your macro-enabled spreadsheet as .xls (old Office format) instead of .xlsm.
See this thread:
Does this thread help you?
Apparently Companion version 1.2.5 supports macro-enabled Office documents.
Hi @KC Wong
thank you for the quick reaction, but unfortunately, It did not solve my problem!
I have installed the most recent version (1.3.1) and actually the problem is before editing.
It does not recognize the "xlsm" MACRO file as you can see in the first post. Am I doing anything wrong?
I created a completely new page to make sure there is no bugs behind it.
MESSAGE/OUTCOME: "No appropriate attachments"
Hi @Thiago Hermida ,
This is not a bug with Atlassian Companion, rather the "Office Excel" spreadsheet viewer macro (also known as Office Connector) does not support XLSM format.
I found two related bug tickets:
https://jira.atlassian.com/browse/CONFSERVER-44322
https://jira.atlassian.com/browse/CONFSERVER-40730
You should be able to edit the file in Atlassian Companion. You can view the file using the Attachments Macro or Attachments Page. Also the attachment thumbnail on the view page should have an edit button when you hover over it.
Alex K (Senior Developer at Atlassian)
Hi @Alex K, many thanks for your support.
Nevertheless, I got confused about your last message.
Below you will find both statements:
1. Office Connector does not support XLSM format
2. You should be able to edit the file in Atlassian Companion
How can I solve my problem? Do you have any other suggestion?
Best regards,
Thiago
My point is that the Excel macro does not work with XLSM files at this time. This is a bug and I shared related bug tickets.
Atlassian Companion is separate. There are ways to use Atlassian Companion other than the Excel Macro. Atlassian Companion supports XLSM.
Alex K
Hi @Alex K, many thanks for the quick reply.
"There are ways to use Atlassian Companion other than the Excel Macro."
Would you mind to share some of them?
Best regards,
Thiago
I mentioned these in my first comment. You can use the attachments macro - there will be an edit button for each attachment, similarly the attachments page will have an edit button associated with each attachment.
Also if you simply embed the attachment like you showed in this screenshot
Once the page is published, if you hover over the thumbnail, there will be an edit icon (depending on your Confluence version, I think it should be above 7.5)
See "other ways to edit files" here: https://confluence.atlassian.com/doc/edit-files-170494553.html
Alex
