Sign up Log in
Auto link JIRA key in Confluence
Neal Culiner
June 1, 2015
I'm not sure if we had this before or if it's available.  When I type in a key/case such as AI-1001 in a Confluence page we'd like it auto-detected and linked to the JIRA case in the AI project.
Is this possible?
Thank you.
P.S. Using the latest versions of all "server" not cloud.
5 votes
Chander Inguva
June 1, 2015
Hi Neal,
                When JIRA and Confluence are linked to each other using Application Link.
In Confluence page, You can insert JIRA Key as follows
  • Open a page on which you want insert JIRA key in Edit Mode.
  • Click on Insert and check on JIRA Issue/Filter Macro, type AI-1001 and press enter and click Insert.
  • This Inserts the JIRA key on the page.
  • If you want to link a confluence page on a JIRA Issue, click on link under "More" and select Confluence Page tab for a corresponding wiki page to be linked on that issue.
Hope this helps
Regards
Chander Inguva
Neal Culiner
June 1, 2015
Thank you, aware of that, just wanted to know if typing AI-1000 would auto-detect as a link to JIRA case.
Like 16 people like this
Fabian Hußl
as far as I know this is not possible.
In this context we have recently released an app called Viable Issues. The app adds the functionality to create Jira issues from an AUI button in Confluence and lists those issues that were created directly from this page.
Reference to our Marketplace documentation.
Fabian
appsparkler
June 4, 2020
As of June 04, 2020
Typing `{` gives a list of things-to-do.
Good Luck :)
Andrew Walker April 25, 2020
as of Apr 25 2020 -
-- use "/" to call macros
-- "jira" for jira macro
-- enter desired search tag
-- enter!
Ben Stiff
July 21, 2020
/j - works too
Tara Lynne Collier June 2, 2015
If AI-1000 is in your default project the link is dynamically created in the confluence wiki pages when typing in the case number...occasionally.  I've had it not dynamically link 100% of the time and have yet to figure out the how's/why's of when it creates and when it does not. I have recently learned that if the JIRA project is not the default project then you must do the extra clicks and link via macro.... which doesn't give you the option to turn off the preview and display a discrete inline link and is extra clicks.
Jobin Kuruvilla [Adaptavist]
June 1, 2015
If you copy the entire issue link, Confluence will auto detect as long as the JIRA instance is linked to the Confluence instance. If not, you can use the "JIRA issues" macro to insert the link.
Neal Culiner
June 1, 2015
Like 4 people like this
June 1, 2015
No, it won't. Maybe you can write a user macro to do that but never tried it!
Like Mike Roger O Sullivan likes this
June 1, 2015
Even a user macro will need the contents to be written inside the macro though. Maynot be what you need!
sunk818
JTOL - If you had functionality that can look up JIRA issues using @ that would be a quick way to perform a lookup. Maybe @Integration Teamcould give you a list of most recently created/updated JIRA issues. But URL method seems pretty easy too. This would be a small improvement and not sure its worth the effort.
Like 2 people like this
Iwona Kalinowska March 14, 2019
Do you know if there is any video tutorial available for the above instructions?
Andrew Gallagher November 15, 2019
Only in some contexts. If you paste a link inside a meeting note, it detects the jira issue when viewing the meeting note itself, but not when viewing the summary of meeting note tasks. Only the full jira macro works in both contexts.
The popup box for the jira macro is painful to use. If I know the exact issue ID, why do I have to type it into a search box?
Like Lanny Heidbreder likes this
Upcoming Confluence Events
