how I can use autocomplete with soy
input
class
"autocomplete-page"
data-max
"10"
data-none-message
"No results"
data-template
"{title}"
I have a bug with {title} in soy template file.
Any suggestions on what is wrong ?
Thanks.
Same problem in 2016 as well. Reason is: {title} compiles as Soy start tag.
But I found workaround:
data-template="{literal}{title}{/literal}"
I'm also trying to achieve something similar. Have you had any luck trying to get it to work?
