I am creating a new Blueprint and already have a few experience on that.
I am trying now to have a Blueprint with multiple wizard pages, and I want to be able to navigate between those wizard pages depending on a choice the user did on the first page.
Let me explain :
On page 1 of the wizard, User will have to chose between 2 options,
then depending on his choice, I want him to navigate either :
- On page 2/3/4 then End the Wizard.
- On page 5/6/7 then End the Wizard.
I know from the documentation : https://developer.atlassian.com/server/confluence/javascript-api-for-blueprint-wizards/
I can use nextPageId, to redirect directyl to page 2, or to page 5 after the user did the choice on page 1,
But I dont know how to specify that the wizard should end on page 4.
If I leave the nextPageId parameter empty on page 4, it will use the next dialog-page (e.g page 5) as defined in the atlassian-plugin.xml file.
I want to be able to specify something like nextPageId="end", or current page state to final step,
Is there any way to achieve this?
Thx,
Michael
