I have installed my language pack for my native language, Norwegian, to Confluence. I did download the file from https://translations.atlassian.com.
The problem is that some buttons turned up pretty messy, it looks like it is also showing the key for the button. This problem is only in Norwegian. If i try to change to English og German or something else the button looks fine.
Does anyone know how to fix this?
OK, Jacek- I have fixed this now.
It was a browser specific problem (Google Chrome). Everything looked fine in other browser and from other users. But in Chrome the problem was still there, no matter who I logged in as. But in inkognito mode everything was fine. So when i cleared the cashe it turned back to normal.
I have recently installed InProduct translation for Confluence (great product!), so I guess that's what made the problem.
Thank you very much for your help.
You are welcome. I'm glad it works fine now.
Jacek
Hmm. No success to reproduce it on my side.
Jacek
Let me try to reproduce it locally first.
Does the problem with edit button occur when you try to edit any page?
Hello Jacek,
Thank you for your reply.
I now use Confluence 5.4.3. I updated from 5.2.5 yesterday. To be honest I am not sure if the error accrued before the update, because I just recently installed the language pack.
First I installed the Confluence-5.2.5-language-pack-no_NO.jar. After I discovered the problems I tried to upgrade to Confluence-5.4.3-language-pack-no_NO.jar, but that didn't help.
If you can't reproduce the issue and want team viewer access that is no problem for me. Just let me know.
Thanks.
Hello Christian,
I cannot reproduce the issue on my side. Can you let me know your Confluence version and what version of the language pack you have downloaded?
Jacek
