CQL: Order by created
Kamal Iqlaas Ismail October 1, 2021
Hi , hope all in good time.
We are trying to sort this CQL by the created parameter as per below CQL.
type=page and created >= startOfMonth("-90d")
Referred to the docs, but got the error when compiling
Could not parse cql
CQL that has been tried
type=page AND created >= startOfMonth("-90d") AND order by created
type=page AND created >= startOfMonth("-90d") asc
type=page order by created AND created >= startOfMonth("-90d")
(type=page order by created) AND (created >= startOfMonth("-90d")).
Any pointers we missed or we should look at?
Appreciate your response in advance!
Lee Wonnacott
October 1, 2021
Hey Kamal!
There doesn't appear to be anything wrong with your initial query but I am curious, where you are attempting to run this query? Are you using a third-party plugin?
Kind Regards,
Lee
Appreciate the response Lee!
We are attempting to run the query from our Golang app.
Any other info I should add?
Do let me know!
Lee Wonnacott
October 1, 2021
Hmm, is the app making a call to the Confluence REST API or is it executing the query via one of Confluence's internal Java API's?
@Lee Wonnacott , just confirmed with my colleague
We are making a call to the Confluence Rest API.
Hope this helps!
Lee Wonnacott
October 1, 2021
I was able to get the CQL query working by making a REST call to the following:
 <base_url>/rest/api/content/search?cql=type=page+and+created+>=+startOfMonth("-90d")
 It might be worth trying the same query within a tool like Postman to check it's working as expected before testing it within your app!
I hope you're able to get everything up and running! :D
Like • David Griffin likes this
Yes, I got that working too, but when you add the order by filter, for me the CQL did not work.
Yes, familiar with the Postman tool!
Appreciate the response @Lee Wonnacott !
Have a nice weekend!
