Can I pull data from tables given certain values?
Bar T
Summary page A would like to pull from a table on pages B and C.
We only want to pull data given the priority column has a P1. Is this possible?
Natalie Paramonova [Stiltsoft]
April 9, 2019
Hi Barbara,
I have a couple of solutions for you.
1) If you need to pull tables containing only one row, you can use the Page Properties Report macro wrapped in the Table Filter macro. You can filter the table to display only the rows containing P1 using Table Filter.
2) If you need to pull multiple tables with multiple rows (both manually created or generated with the help of the macros outputting tables), you can use the Table Excerpt Include macro that provides an ability to pull any tables from child pages, from specific pages, from pages by labels and more.
After that, you can use the Table Transformer macro to merge all the tables in one.
The Table Filter macro can help you to hide unnecessary columns and filter rows containing P1.
The workflow may be as follows:
1. Insert the Table Excerpt macro, set the Excerpt name parameter, and place the tables (or the macros outputting tables) within the macro body on every page.
 2. Add the Table Excerpt Include macro on the summary page, specify Excerpt name and select an appropriate Excerpt source.
 3. Wrap the Table Excerpt include macro in the Table Transformer macro, use the default presets or custom SQL queries to merge all the tables in one.
4. Add the Table Filter macro to the merged table to hide unnecessary columns and filter rows.
Let me know if you need more details.
EPS Software Engineering AG
October 8, 2018
Hi Barbara,
Our Easy Dropdown Menu allows to be used as a filter (CQL) in a Page Properties Report. So, P1 would be an item of a Dropdown Menu and you can filter on that. You can find the Easy Dropdown Menu an the Marketplace and the last illustration shows the CQL filter.
Stephan (CEO of EPS Software Engineering AG, the vendor of the Easy Dropdown Menu)
Shannon S
October 5, 2018
Hi Barbara,
It sounds like you might be able to get this to work using the Page Properties and the Page Properties Report macros.
Could you have a look and let me know if you have any questions?
Shannon
Shannon S
October 5, 2018
Also, if this does not help, it wasn't very clear where this information is coming from.
Is this a table you built in a Confluence page or are you using something like Jira issues macro to generate the table?
Shannon
Bar T
Thanks for responding Shannon. Page properties and entire multiexcerpts won't work as we are trying to show only the priority 1 items in the main page.
Confluence Page A shows the high level summary to teams.
Confluence pages B, C, D, etc. all have a table of data that are prioritized.
We only want to show "if table column shows P1, then show this data on the high level page".
Shannon S
October 8, 2018
Thank you for clarifying that, Barbara.
You may want to try instead to use a table add-on. I think that you could built the table you require perhaps with one of the following:
Shannon
atlassian, compass learning path, get the most out of compass, internal developer platform, devex learning path, atlassian learning, transparent architecture, component catalog, improve dev experience, compass platform training
Elevate your skills and enroll in the Compass learning path today! 💻
This learning path offers short, self-paced courses to help software teams systematically manage components and services. Compass provides a unified interface for tracking distributed software architecture and team collaboration.
Learn more!
